July 27, 2026 1:05 pm
Author Topic: sko_ford's A mod  (Read 183700 times)
« Reply #90 on: April 01, 2008 4:30 am »
what radiator will that grille shell be covering?
« Reply #91 on: April 01, 2008 10:08 am »
4 core 60's mustang.  and 40 by my tape its an inch lower
« Reply #92 on: April 01, 2008 2:33 pm »
You will have to toss that tape aside to see if your car has the correct "look" or "flow” body and frame lines can change the way it looks. My A sedan had the radiator taller than the cowl but your eye was not drawn to it cuz of the carbs breaking the line and when I put the radiator support rods in I mounted them lower on the radiator so they were.
« Reply #93 on: April 01, 2008 5:23 pm »
So why are you called Eyeball?
« Reply #94 on: April 01, 2008 9:41 pm »
With your body channeled so much, there may only be so much you can do to lower the grille shell. You may have to adjust (ie. raise) the body a bit. I have a 65 4 core mustang radiator. It's sitting ON the crossmember and my grille shell still sits higher than my cowl too. Unlike Eyeball and using his carbs to break up "the line," I had to use the gas tank to break the line (I didn't have a roof!). On my roadster, theres that imaginary line that goes from the lip on the back of my "cockpit" to the grille shell. I just made damn sure the gas tank broke that line.  It's ok right now, but I will be modifiying the corners of the upper rad. tank so I can lower my shell another inch if needed. You may have to do the same. I'm trying to avoid raising the body to compensate, but you may have to fiddle with the front and rear height of your body just to make the radiator shell look right. My support rods will be used to maintain the flow I want the top of the body to have, but will be closer to the engine than the body "line" so the engine doesn't look like it's sitting so darn low.
You can try my radiator if you need to play with it. It'll turn out great. Just gotta fiddle and stare at it  alot!
« Reply #95 on: April 01, 2008 9:52 pm »
Ross id raise the front of the body before i lowered the rear,  just my .02
« Reply #96 on: April 01, 2008 10:00 pm »
Quote from: "Serious"
I agree. Leaning the grills shell forward so It's almost vertical would change the look of the whole car a lot too.
Of course, do we neccessarily want all of our cars looking the same?
« Reply #97 on: April 02, 2008 12:45 pm »
i am looking at raising the front but i still want to lower the back to cover the frame. what the point in chanel ing a car for it dosent cover the frame
apart
« Reply #98 on: April 02, 2008 12:58 pm »
so i blew it apart last night so i can start fixing and welding the bits and peices that i couldnt with every thing in the way tonight.  and this is my shackle and mount that link to meet so i'm gong to look in to haveing the spring eyes rerolled shorter so this doesnt hit
Re: apart
« Reply #99 on: April 02, 2008 1:24 pm »
I had a similar problem, I re-rolled them my self.
RE: Re: apart
« Reply #100 on: April 02, 2008 2:08 pm »
I think even if you shorten the spring you are still going to bottom out at that point. Is there any way to change the designe and hang it below or make a set like a modle A has on top of the axle.
RE: Re: apart
« Reply #101 on: April 02, 2008 2:31 pm »
I agree with Tim, It needs to have full movement, my spring was so long that the shackles hung straight down. They need to be at about a 45 degree angle to the center of the car.
RE: Re: apart
« Reply #102 on: April 02, 2008 2:43 pm »
to change it to hang below i'd have to cut about 4" out of the kick of the frame and to put it on top would put the u joint right next to my kidny and still wouldnt be far enought apart
RE: Re: apart
« Reply #103 on: April 02, 2008 3:17 pm »
I'll take a pic of mine and post it tomorrow.
RE: Re: apart
« Reply #104 on: April 02, 2008 4:50 pm »
I think you better fix it or it will be a problem that will bother you forever. Plus there is always a chance that something will bend or break over time if it does hit.
