November 05, 2026 10:16 pm
Author Topic: sko_ford's A mod  (Read 186632 times)
RE: Re: apart
« Reply #105 on: April 02, 2008 6:18 pm »
Even if the springs were re-rolled so that the shackles were shallower at, say, 30 degrees instead of 45, wouldn't the spring hit that bracket in a bump or if the car rolled a bit in the corner?
RE: Re: apart
« Reply #106 on: April 02, 2008 10:08 pm »
so who wants to have a frame cutting party
RE: Re: apart
« Reply #107 on: April 02, 2008 11:13 pm »
Can't we just redesign the rearend brackets? They can be designed so they won't hit the spring. It'll be sort of a goose neck, but it'd work.
Re: RE: Re: apart
« Reply #108 on: April 02, 2008 11:57 pm »
I think either way. Cutting the frame should not be too bad either.
RE: Re: RE: Re: apart
« Reply #109 on: April 03, 2008 12:42 pm »
ok so i measured the frame for cuts after work and noticed that the top is 1/2" wider than the bottom, but in the midle the top of where i d put the 4" is 1/8 wider so no problem there that'll pull but i have a coiuple thoughts to fallooww....
« Reply #110 on: April 03, 2008 2:03 pm »
on cutin the frame i have three options (that come to mind)
1  just what the 4" out of the middle
2 cut it on the seam at the bottom and cut the 4" out to meet the seam
3 cut the rear member out cut the verticle down make a new uper horizonal and re fit the cross member
« Reply #111 on: April 03, 2008 9:36 pm »
I like #2
Re: RE: Re: RE: Re: apart
« Reply #112 on: April 03, 2008 9:48 pm »
I like #2
You like poop. :albino:
RE: Re: RE: Re: RE: Re: apart
« Reply #113 on: April 03, 2008 9:57 pm »
ok brownie you like #2 but that one is the hardest with trying to match the angles back up to put it together
« Reply #114 on: April 03, 2008 10:16 pm »
Take it out the middle of the kickup......the pickup bed will cover the surgury. :)
« Reply #115 on: April 03, 2008 10:22 pm »
your funny...lookin
« Reply #116 on: April 04, 2008 11:08 am »
yep out of the middle its markd and ready to cut just nee to make the sleave to slide inside for backing.
sko_ford's A mod
« Reply #117 on: April 04, 2008 2:14 pm »
Ross as promised. This dose work, I have a rubber snubber off the bottom of the spring that will hit the top of the banjo rear end before the springs hit the mounts. The spring has settled in time, when I first got it together the shackles where at more of a 45.
scrap
« Reply #118 on: April 08, 2008 11:27 am »
so have had marked to cut 4" out of the kick on the frame i decided that tonight was the night to give it the wack.  and with the first cut it sprang a 1/2" from 33.75 on the bottom ro 34.25 on the top.  so am i in the recycleing business or could i push that bottom out with a porta power and het the halfs to line up sleave it and weld'em back together?
RE: scrap
« Reply #119 on: April 08, 2008 2:10 pm »
So I take it you did not weld supports in b4 you cut it? You should be able to get it back in alignment but does the bottom need to go out or the top in?
