December 05, 2025 8:29 am
Author Topic: 32 ROADSTER  (Read 227581 times)
« Reply #45 on: January 10, 2007 4:49 pm »
Here are a few pics of the steering box in place. I had to trim back a little of the x member to make room for it. Now it looks like the box is too close to the rear exhaust port. I see Reds headers makes headers for a 32 frame with a F1 box so I may end up ordering a set up. I do have a set of old headers I may try to modify too but I am not sure everything is in the correct spot yet.
« Reply #46 on: January 12, 2007 5:48 pm »
Well I got it up on all four tires last night. My bushing showed up for the shackels and it worked.
« Reply #47 on: January 13, 2007 1:14 am »
That looks great- I'd say it's coming together quite quickly!
« Reply #48 on: January 13, 2007 4:08 am »
cripes, you'll be done before me-painted and everything
« Reply #49 on: January 16, 2007 3:04 pm »
I started fitting the cross braces last night. I'm not sure how I will attach them to the frame yet.
« Reply #50 on: January 16, 2007 3:22 pm »
Looks good...nice looking set of rear radius rods on there by the way...
RE: 32
« Reply #51 on: January 16, 2007 3:30 pm »
I also got the throttle pedal moving again and mounted to the firewall.
« Reply #52 on: January 19, 2007 2:43 pm »
I decided to weld a plate to the inside of the frame rail to mount the cross braces. They needed allot of surgery to work. They are also mounted upside down compared to how they were born. Once they were tacked in they eliminated frame flex I was getting when I jumped up and down on the center of the X.
« Reply #53 on: January 27, 2007 7:23 am »
I got the tranny mount finished tonight.
« Reply #54 on: January 29, 2007 3:06 pm »
I have decided to ditch the square back spindles and use '32 spindles. The 32's have an integrated steering arm so I don't have to use a bolt on steering arm. This meant I had to rework the top of the king pins since I am not going to be using mechanical brakes. I cut the ball of and then file finished the tops. That is about all I got done yesterday. I had to order a spacer kit that will allow me to run the juice backing plates on the early spindles. I have found that this kit is only made up of 2 model a piston rings and 2 model a valve seats but I didn't have any of those laying around.
« Reply #55 on: January 29, 2007 4:08 pm »
Tim, I did the same with the 33-34 front end on my '28. Can't tell from the pic, how did you fill the hold that goes through the center of the king pin??
I knew about the piston ring, I didn't know the part that goes on the spindle was a valve seat. I ordered the kit from Speedway. It comes with no instructions. Didn't say anything about filling the holes in the backing plates and re-drilling new holes.
« Reply #56 on: January 29, 2007 6:05 pm »
I welded the top shut and built up the edge where the ball was. The directions I have seen say just to file the holes to fit. They look like they are very close to the edge. They also show using washers on the inside of the backing plate like this.
« Reply #57 on: January 29, 2007 7:04 pm »
Yes they are close to the edge, that's why I welded them shut and re-drilled. You can use a smaller washer if you weld the old hole up.
« Reply #58 on: January 29, 2007 7:06 pm »
very very cool Tim...
« Reply #59 on: January 29, 2007 8:06 pm »
Looked at the king pin pic again. Your middle name Sam?? :0)   What's the bottom, 32 ?
