June 09, 2026 6:39 am
Author Topic: sko_ford's A mod  (Read 178218 times)
have you hugged your drill press today
« Reply #195 on: February 19, 2010 10:02 pm »
1540 sworles 3 hrs
RE: have you hugged your drill press today
« Reply #196 on: February 20, 2010 3:35 am »
Wood dowel with rubbing compound?
« Reply #197 on: February 20, 2010 3:50 am »
1 inch wire brush
« Reply #198 on: February 20, 2010 6:09 am »
Looks great Ross.....pull that tape and let's see what ya got.
« Reply #199 on: February 20, 2010 3:47 pm »
i plan to today. i'm a little nervous
« Reply #200 on: February 20, 2010 3:59 pm »
can you explain the process Ross, what is the purpose of the tape?
ross i saw this on the hamb.  this could be you.
tape
« Reply #201 on: February 21, 2010 6:45 am »
the tape is not part of the turning process it was put on so i didnt mar the freshly surfaced face of the dash while i broke the bottom edge and rolled the top one.
as for the turning that was easy. 1 inch wire brush lapping each brush mark by half then moving my guide by a 1/2 inch thusly lapping it by half again and stagering each row so they didnt line straight up
« Reply #202 on: February 21, 2010 3:59 pm »
Here's a working shot. Ross also taped the wire brush so that the size stayed consistent.
« Reply #203 on: February 21, 2010 4:30 pm »
if i were to do it again i would usea hose clamp on the brush insted of tape to keep it to size
« Reply #204 on: February 21, 2010 4:49 pm »
I was thinking about a hose clamp but was wondering if the screw would throw off the spinning of the brush.
« Reply #205 on: February 21, 2010 5:32 pm »
it was only spinning at 200 rpm so i dont think it would be a deal breaker.
Re: RE: have you hugged your drill press today
« Reply #206 on: February 22, 2010 1:20 pm »
1 inch wire brush
Did you do it dry?? no lube??
« Reply #207 on: February 23, 2010 1:12 am »
yep dry, there are some imperfections in some of the turns due to some buildup in the brush but i like it and and now fro the fasinating part brass machine screws 10 of em with a 3/8/of an inch head
« Reply #208 on: May 22, 2010 1:33 pm »
headers are almost done. Mud is on. Almost time to cypher on paint
« Reply #209 on: June 07, 2010 2:25 am »
