November 05, 2026 9:38 pm
Author Topic: sko_ford's A mod  (Read 186549 times)
sko_ford's A mod
« Reply #225 on: July 01, 2010 10:10 pm »
1st coat of primer whent on thin and kinda rough
sko_ford's A mod
« Reply #226 on: July 02, 2010 12:23 am »
good progress!
sko_ford's A mod
« Reply #227 on: July 02, 2010 1:08 am »
i found out that the best primer gun i've used is my industrial 2.8 gal pressure pot from work, its got a devilbiss HVLP gun with a 2.0+ tip (cant remember for sure). there is so much adjustment with pressure you can get the primer to lay down extra smooth, plus with the pot you can mix an entire gallon at once, and without a cup on the gun you can shoot at any angle you want. its marvelous!
sko_ford's A mod
« Reply #228 on: July 02, 2010 3:43 am »
problem was the gun gumed up lil too much activator I think
sko_ford's A mod
« Reply #229 on: July 05, 2010 3:21 am »
blocked, sealer in the mornin color tomarow night
sko_ford's A mod
« Reply #230 on: July 05, 2010 3:34 pm »
she's sealed
sko_ford's A mod
« Reply #231 on: July 05, 2010 4:33 pm »
On the edge of my seat.........
sko_ford's A mod
« Reply #232 on: July 05, 2010 5:56 pm »
as you should be ;-) it's gona be damn cool if I do say so myself. Hope I dont run the paint
sko_ford's A mod
« Reply #233 on: July 06, 2010 3:01 am »
if you get a run, just run it right off the panel!
sko_ford's A mod
« Reply #234 on: July 06, 2010 3:27 am »
I'm an industria painter and I'm not very good at it
Highly Rossified!
« Reply #235 on: July 06, 2010 3:31 am »
Stopped over to lend a hand/watch Ross kick some ass!
RE: Highly Rossified!
« Reply #236 on: July 06, 2010 3:32 am »
That's kinda dark, doesn't show the color well......
« Reply #237 on: July 06, 2010 6:35 pm »
I'll keep checking back for an update (pic)
sko_ford's A mod
« Reply #238 on: July 07, 2010 9:30 pm »
Let's see some color!!!
sko_ford's A mod
« Reply #239 on: July 07, 2010 10:09 pm »
well I got some sanding to do I went to spray a quik coat to fill a tiger stripe and ran the whole pass side
