November 04, 2026 11:11 pm
Author Topic: Pinstriper49's 49 Shoebox (Formerly SKOFORD'S)  (Read 161412 times)
Offline tokyo
  • dongs!
    • My50merc
Re: Pinstriper49's 49 Shoebox (Formerly SKOFORD'S)
« Reply #165 on: July 21, 2011 10:05 pm »
This build is really well documented...for trim - there is soo much to look at and modify I would definitely wait on that.  Nice desoto modification.
Are your plans to run a stock interior?
I once had a really big deck.
« Reply #166 on: January 15, 2013 1:56 am »
Thanks Tokyo!  I will not be running a stock interior ;)
« Reply #167 on: January 15, 2013 2:05 am »
Ok, so last night I put together the taillight housing idea that I have had in my head for the last couple of weeks. In the end, it'll take just two bolts to install each taillight. No screws, no "proper alignment" issues... no B.S.
I wanted to be able to mount the taillights in through the trunk, without having any visible fasteners, but also to do it in a way that some Shadetree Engineer from the past would have done it. I came up with a simple "taillight tensioning" system that consists of three basic pieces. A backplate, a top plate, and a bottom plate. Eventually, the top and bottom plates will be welded to the body when I form the rear taillight sections. The backplate is designed to simply slide into place from the inside of the trunk, with the taillight lens.
First, I made the backplate. I just used 1/4" round rod in the shape of the taillight lens, but a bit bigger so it would seal nicely later on. This piece will eventually hold the pigtail and lights as well. I haven't gotten that far yet. I put a tab on the top and bottom of the backplate with a 5/16" nut welded to each tab. These nuts are the basis for my tensioning system. I simply put a bolt through each one, and tighten in down onto my top and bottom plate. This holds the taillight in.
Please refer to photos.
« Last Edit: January 15, 2013 2:06 am by pinstriper40 »
« Reply #168 on: January 15, 2013 1:44 pm »
The lens.............. 54 Merc??
« Reply #169 on: January 15, 2013 2:05 pm »
Looks well thought out. Nice job.
« Reply #170 on: January 16, 2013 1:45 am »
Yes Tom the lenses are '54 Merc.  I was debating between them and '55 lincoln, but the '54 merc taillights are much more reasonably priced.
Thanks Ryan!  I hope they're as functional as I plan for them to be.
Offline Fordman1
« Reply #171 on: January 21, 2013 9:22 pm »
Really nice work so far.  Interesting that most of the other cars posted in this thread I also have saved into a folder for Shoeboxes!
« Reply #172 on: February 03, 2013 5:39 pm »
 Thank You!  I think a good lookin' 'box is a good lookin' 'box...
Offline Kustom Dallas
  • Kustomer
  • Kustoms Forever
« Reply #173 on: February 04, 2013 5:28 am »
Toke
"You own a car nobody wants." Serious
"The beer I had for breakfast wasn't bad so I had one more for dessert" Johnny Cash
« Reply #174 on: February 22, 2013 6:10 pm »
Anything constructive to say Dallas?
