December 05, 2025 10:07 am
Author Topic: Banjo rear *****THANKS OVERSPRAY*****  (Read 5984 times)
« on: October 03, 2008 5:17 pm »
Looking for a 39-48 banjo rear. Looking for one with a good surface where the outter bearings run.
banjo
« Reply #1 on: October 04, 2008 12:56 am »
I p.m'd you Tim...
Offline eberhama
RE: banjo
« Reply #2 on: October 04, 2008 1:19 am »
I've got a '46-'48 rear, no bones or spring but everything else is there, don't know what shape the bearing surface is like, $75. Its here in moorhead.
RE: banjo
« Reply #3 on: October 04, 2008 3:21 am »
If you don't find one with good outer ends, they make sleves that will go over the end. You do need to turn end down for them to press on.
RE: banjo
« Reply #4 on: October 04, 2008 5:18 am »
I turned mine down and put the sleeves on. Worked relatively  well. The first one did anyways. . . but .001 interference is no match for a hammer and a block of wood as long as the sleeve is still warm. ;)
« Reply #5 on: October 05, 2008 6:44 pm »
I have a 39 without brakes and drums.  I picked it up at the roadster swap last year for $50 and I don't know why, maybe because it came out of a barn stored car with about 60,000 miles on it and I figured someday Eyeball would need one.  It looks pretty nice.  I had it sold in Bismarck, but no show on the buyer.
$50 or trade for ???
« Reply #6 on: October 05, 2008 8:07 pm »
I'll take it. R u going to the roadster swap? Is the torque tube n drive shaft on it?
« Reply #7 on: October 06, 2008 12:49 am »
No torque tube or shaft.
I'm still up in the air on the Swap.  I haven't nailed the day off yet.
I'll be in touch.
