October 30, 2026 11:10 pm
Wanted
Banjo rear *****THANKS OVERSPRAY*****
Topic: Banjo rear *****THANKS OVERSPRAY***** (Read 6359 times)
Moderator
October 03, 2008 5:17 pm »
Looking for a 39-48 banjo rear. Looking for one with a good surface where the outter bearings run.
tracywiedrich
Oh, I get it...
banjo
October 04, 2008 12:56 am »
I p.m'd you Tim...
eberhama
Street Rodder
RE: banjo
Reply #2 on:
October 04, 2008 1:19 am »
I've got a '46-'48 rear, no bones or spring but everything else is there, don't know what shape the bearing surface is like, $75. Its here in moorhead.
Tom
RE: banjo
Reply #3 on:
October 04, 2008 3:21 am »
If you don't find one with good outer ends, they make sleves that will go over the end. You do need to turn end down for them to press on.
racerjohnson
RE: banjo
Reply #4 on:
October 04, 2008 5:18 am »
I turned mine down and put the sleeves on. Worked relatively well. The first one did anyways. . . but .001 interference is no match for a hammer and a block of wood as long as the sleeve is still warm.
overspray
Oh, I get it...
Reply #5 on:
October 05, 2008 6:44 pm »
I have a 39 without brakes and drums. I picked it up at the roadster swap last year for $50 and I don't know why, maybe because it came out of a barn stored car with about 60,000 miles on it and I figured someday Eyeball would need one. It looks pretty nice. I had it sold in Bismarck, but no show on the buyer.
$50 or trade for
Moderator
Reply #6 on:
October 05, 2008 8:07 pm »
I'll take it. R u going to the roadster swap? Is the torque tube n drive shaft on it?
overspray
Oh, I get it...
Reply #7 on:
October 06, 2008 12:49 am »
No torque tube or shaft.
I'm still up in the air on the Swap. I haven't nailed the day off yet.
I'll be in touch.
Wanted
