September 21, 2026 11:08 pm
Author Topic: BARN FIND!!!!  (Read 115024 times)
RE: Fresh lookin engine bay!
« Reply #45 on: January 29, 2009 11:41 pm »
WOW! very nice... i guess winters are good for something.........
Body in Primer!
« Reply #46 on: April 14, 2009 9:31 pm »
As usually happens, I've gotten way deeper into this project than I had planned.  It's now apart down to the bare body on the frame and drive train.
But it's far enough that we got it in primer today.  One good coat of epoxy and then (the "Overhaulin" way)....FIVE coats of polyester primer. Now a bunch of block sanding...hopefully I can get the body in color and back together before BTT50's....good luck....I'm not 30 any more..... :roll:
RE: Body in Primer!
« Reply #47 on: April 14, 2009 10:22 pm »
Good lord.... I thought you would be driving it by now.......what color?
Re: RE: Body in Primer!
« Reply #48 on: April 14, 2009 10:28 pm »
what color?
Not it's original dark grey....but original for the year....Coach Maroon....a really dark maroon.
Offline Lord_of_the_Dance
RE: Re: RE: Body in Primer!
« Reply #49 on: April 14, 2009 10:43 pm »
Jake that will be a really nice color on there!
« Reply #50 on: April 14, 2009 11:50 pm »
so you got the mix down?
« Reply #51 on: April 14, 2009 11:55 pm »
That's going to be really nice.  I can't wait to see it- sorry I haven't gotten out there... it'll happen soon!
« Reply #52 on: April 15, 2009 1:04 am »
Looks good.  I wish I was at that point.
« Reply #53 on: April 15, 2009 2:25 am »
i'll second that
Re: RE: Re: RE: Body in Primer!
« Reply #54 on: April 15, 2009 4:10 am »
I wanted to paint it in single stage urethane to have the old paint look, but PPG only offers most old colors in the premium ($) Global base coat line. I played with Omni single stage and can match it spot on, but it needs to go over black.  So it's somewhat transparent which does not lend itself well to painting pieces.  I even had the PPG color lab play with it, trying for single stage and they gave up as well.  So I'm not sure what I'll do, but will decide which way to go within the next week.
RE: Re: RE: Re: RE: Body in Primer!
« Reply #55 on: April 15, 2009 1:23 pm »
WTF Jake, it's not a barn find anymore. :(   Oh yeah nice paint booth. :wink:
Re: RE: Re: RE: Re: RE: Body in Primer!
« Reply #56 on: April 15, 2009 1:48 pm »
I got carried away and now it's too late to stop. It will still be just a basic build.  Nothing fancy....body didn't come off the frame. Tried to keep it simple, but went a little farther.  :?
« Reply #57 on: April 15, 2009 6:34 pm »
HMMMM,  PPG--good stuff.  You must have forgot there are other good or better products that can get you what you want color wise probably with better hiding.
« Reply #58 on: April 15, 2009 8:15 pm »
Quote from: "overspray
HMMMM,  PPG--good stuff.  You must have forgot there are other good or better products that can get you what you want color wise probably with better hiding.[/quote
For obvious reasons I use PPG.  It's what we teach.  But if I could find another brand of single stage urethane or acrylic enamel that matched, I'd consider it. I'd like to single stage it to be similar to what was offered in the 40s. Alkyd - no thanks...not that similar.
Here's the PPG match - #916040.  A Ferrari color called Masolac.  Original Ford color - IM 1471 - Coach Maroon.
If you have any ideas....Talk to me Reed.....Thanks.
« Reply #59 on: April 16, 2009 8:13 am »
I'm a little surprised that NDSSS only teaches PPG.  That seems like a disservice to the students.
BASF (RM, Glasurit),  Akso-Nobel (sikkens-utech), Dupont (Spies Hecker, Nason, Standox), Sherwin Williams (Martin Senior, Acme, Western), all have very good single stage urethanes and most should be able to cross reference color numbers or paint codes or have chip books by shade and color.  They all should be compatible with your 2K undercoat system.
I recently went down to the Sikkens jobber and used their "color-map" book to match a color in single stage.  I have also used Dupont's color book by shades.  If I find a matching chip, I check the formula for poor hiding toners or tints before I move on to getting a small amount for shooting a test panel.
BASF
https://www.basfrefinish.com/cgi-bin/capbsm/java/DirectLink.do?action=GuestLogin&menuName=HUB_MENU&directAction=Home&fromhttpsredirect=Y
SW
http://www.sherwin-automotive.com/
akso nobel
http://www.akzonobel.com/cr/
Dupont
http://pc.dupont.com/
