June 20, 2026 5:00 am
Author Topic: finned coil...or is it?  (Read 8077 times)
« on: January 29, 2008 4:28 am »
I'm going to try to post one pic on this post an the finished product on the other one.  Maybe that'll work.  Some of you know that I was looking for a finned something or another for a master cylinder reservoir.  Well, Russian saved the day and found this old finned aluminum 6 volt coil. I busted out the top ceramic part with a hammer, then cut off the retaining ring.  I then gutted it, cleaned it up, and rounded off the bottom fins.  next I went to Otto's Machine and had them weld in the tube made from solid rod.  I ground down the weld, made a cap on the drill press with a hole saw, and polished it up with  emery cloth and the angle grinder with a 3M roloc disc.  then I went after it with 80 and 120 grit sandpaper.  I got a discount on a tap and tap handle, and tapped it out. I later decided to round the top part of the fins too...I thought I'd share some pics of my "recycled" aluminum. Now it's my reservoir. Thanks Russian!
And the (semi) finished product...
« Reply #1 on: January 29, 2008 4:30 am »
Hope this works... :?
RE: And the (semi) finished product...
« Reply #2 on: January 29, 2008 4:37 am »
thats pretty sweet...
« Reply #3 on: January 29, 2008 4:51 am »
Looks great....
I also just successfully merged your two topics......damn...a moderators work is never done. :albino:
« Reply #4 on: January 29, 2008 4:58 am »
Eyeball, Ladies and Gentlemen!
« Reply #5 on: January 29, 2008 1:53 pm »
Nice work!
Got another one laying around?
Offline boristheblade
« Reply #6 on: January 29, 2008 2:27 pm »
Haha, no.  I have no idea what it came off of, and i never woulda let it go if it was a 12V.  Ya got lucky striper :P  Found a pair of cordless shears to hack up the seat cover with, still looking for a cheep turkey carver to fix the foam - hopefully i'll have some time this week, tests are swampin me already.
« Reply #7 on: January 29, 2008 3:51 pm »
I might be getting another one tonight....as long as I don't get outbid.....
« Reply #8 on: January 29, 2008 6:34 pm »
Damn, I have been looking all over for a finned 6 volt coil.
« Reply #9 on: January 29, 2008 9:37 pm »
I don't blame ya, they are extremely sexy. Shoulda posted in the wanted adds, I was hesitant about giving it up, but pinstriper had that gleam in his eye.  I don't think I'll ever have the urge to build a 6V car, so I'm just happy that it will serve a purpose.  It sucks getting attached to parts, but I guess that will happen when they sit on your desk for 5 years.
« Reply #10 on: January 29, 2008 10:52 pm »
Well evidently not ALL over. :D
« Reply #11 on: January 29, 2008 11:24 pm »
That is a great use of a used coil.........I am no longer a BIG fan of used ones.
« Reply #12 on: January 30, 2008 12:27 am »
I should have let you have the first crack at it with the hammer, mr. eyeball!
« Reply #13 on: January 30, 2008 10:41 am »
you should post this on the puke can tech on the hamb
« Reply #14 on: January 30, 2008 8:35 pm »
I might just do that...I won the other one on ebay...
