October 29, 2026 5:49 pm
Author Topic: 94 Carb help?????  (Read 5141 times)
wlspdshop
94 Carb help?????
« on: December 07, 2006 11:26 pm »
Well its tech month so here we go…..I need some help….I have a pile of  94 carbs and I am trying run six.  My question is are they all the same CFM or is each ID model of 94 different.  I don’t quite have 6 of one model (4 EAB, I have three of 8ba’s and a few mismatchs of others,  but I have to check what they are) I will have to look tonight when I get home from work to see exactly what I all have.
So any suggestions on what 94’s I can run together.  Also is there one ID model that is better then the other.  Thanks for the help guys….
RE: 94 Carb help?????
« Reply #1 on: December 08, 2006 12:10 am »
I have mixed them. I know there are some CFM differences but I think it is mainly on the larger truck carbs. Allot of em have the venturi size cast into the housing. Just jet them the same. I'll see if I can find any other info. I may have some 8ba's that I would trade for some other models too.
wlspdshop
« Reply #2 on: December 08, 2006 3:04 am »
I will dig through my carbs this weekend when it is a little warmer and see what I have.
wlspdshop
« Reply #3 on: December 12, 2006 2:44 pm »
Well, I will need two more 8ba's and I will be set for this engine.  Eyeball if you have any 8ba's you want to part with let me know. Thanks.
« Reply #4 on: December 12, 2006 2:59 pm »
I might I'll look tonight. Do you have others to trade?
wlspdshop
« Reply #5 on: December 12, 2006 5:25 pm »
I have a nice EAB with 15/16 on it and another that has 91-99 with 15-16 on it as well.
« Reply #6 on: December 16, 2006 2:47 am »
I have one 8ba. You will need to change the base as the one that is on it has a modified shaft for multi carb setup.
wlspdshop
« Reply #7 on: December 16, 2006 5:28 am »
PM sent...
