July 27, 2026 11:19 am
Author Topic: sko_ford's A mod  (Read 183696 times)
RE: scrap
« Reply #120 on: April 08, 2008 2:24 pm »
the bottom is going to have to go out since thats where the flex is.  i didnt think that there was as much stored energey as there was when it popped free
RE: scrap
« Reply #121 on: April 10, 2008 5:10 pm »
Didja cut the other side yet? I looked at it last night and I think once you cut the other side and split the diff it should not need much of a push to come into alignment. I think a little push from a porta power and at the same time a bit of pull on the top and you should be good to go. I think it will be allot easier to pull the top in since it is just the model A cross member in there and the bottom has the GIANT X.
RE: scrap
« Reply #122 on: April 11, 2008 8:28 pm »
get some angle iron, cut notch them to the widths you need, and use a ratchet strap to pull it together and tack them on....
RE: scrap
« Reply #123 on: April 14, 2008 6:55 pm »
i hvent had a chance to cut the other side since ive been out sick since tuesday but may be tonight.
the bottom i can move by habd the top is much to ridgid to move so the bottom wil have to do the workin
RE: scrap
« Reply #124 on: April 15, 2008 10:04 pm »
both sides are cut and i hope to have it sleaved up tonight
RE: scrap
« Reply #125 on: April 16, 2008 12:42 pm »
the rear kick up is now 11.5".  i just nead to square it up and i can weld the frame back together
RE: scrap
« Reply #126 on: April 16, 2008 2:07 pm »
What method are you using to squaring it up?
RE: square
« Reply #127 on: April 16, 2008 2:20 pm »
x'es of tape.  i have to releval the whole frame and check heights.  really there isnt much i can do but make sure its level.  the two haves were solid so there shouldnt be any real squareing
RE: square
« Reply #128 on: April 18, 2008 3:27 pm »
the fame is back together and will be a roller again shortly
roller
« Reply #129 on: April 22, 2008 10:40 am »
well i got a roller again the only welding left to do on the fame is for shock, radiator, and body mounts. and the sone on the rear.  the spring issue has been fixxed and the ass end looks much cooler i just wish the pumkin on a 9" was centered but oh well. the back of the body is coming down and hope fully will be togeter shortly
enjoy the pics
« Reply #130 on: April 22, 2008 2:32 pm »
Looks good Ross. Have you ever thought of putting on those side nerf bars to make getting in and out easier?
« Reply #131 on: April 22, 2008 2:36 pm »
I agree that back does look better.
« Reply #132 on: April 22, 2008 10:49 pm »
Nice work!!
stubless
« Reply #133 on: June 02, 2008 4:21 am »
well ive only got a bit done lately but i should be able to paint chassis shortly.  and there is no longer a way to put a box out back :)
RE: stubless
« Reply #134 on: June 02, 2008 5:13 am »
Wouldn't one want to wait to paint the chassis until the whole car is mocked up or assembled? There are tabs here, brackets there. . . oh shit, this doesn't fit, gonna have to move the pedals, etc. Just my .02 and you're car will still probably be done before mine:)
