November 05, 2026 9:50 pm
Author Topic: sko_ford's A mod  (Read 186584 times)
pezfest
RE: roller
« Reply #30 on: April 05, 2007 7:31 am »
Ross, good job on the conez.  Before anybody makes too much fun of Lunchbox's work, I've got a story for you about blown brake lines, a very heavy car, duct tape, a two-hunnert-mile trip and our pal, Ross. . . .  Vintage Rossisms to come.
RE: roller
« Reply #31 on: April 08, 2007 2:23 am »
Wheels are done.....finally. :roll:
« Reply #32 on: April 08, 2007 2:30 am »
rad
seats
« Reply #33 on: April 24, 2007 3:43 am »
so i havnt goten a whole lot done since toppers but here is apic of the seats mr dr iii esq brought over.  i think they might be a little high since thay are sitting on the concrete and not the channeled car floor
RE: seats
« Reply #34 on: April 24, 2007 4:46 am »
I wonder if you could cut the back of the frame down a few inches and make em work.
BTW what is that is the back ground? hahaa JK. :albino:
RE: seats
« Reply #35 on: April 24, 2007 3:18 pm »
The backrests sit directly on top of the bottom cushions, but maybe you could squish'em a little and drop the backrests on the seat frames. Or just move the bottom cushions forward a few inches and drop the backrests all the way down.
RE: seats
« Reply #36 on: May 09, 2007 5:44 am »
just a little add i got the motor moved 2 inches back with just a floor jack a peice of tube and a pipe wrench
RE: seats
« Reply #37 on: May 09, 2007 1:44 pm »
I think it needs fenders. :D
firewall chanell
« Reply #38 on: May 25, 2007 3:58 am »
so now that the motor is down and back to where it will be i started on the the cowl part of the channell.
5 1/4 inches not six but it looks good i also rounded the edge of the opening on the fire wall at the bead for the trany hump
RE: firewall chanell
« Reply #39 on: May 25, 2007 5:20 am »
I cant believe how clean the workbench is.  looks good.
« Reply #40 on: August 07, 2007 4:55 am »
so last friday i blew the frame and axles apart and took the frame over to eyeballs.  where we pinched the front from 24.5 to 20 inches. so the crossmember would sit behind the the grill.  while pinching we change said crossmember from the square and notched piece to a round one with a suicide perch with spring on top.  so the perch sticks right out of the grill
RE: -4.5
« Reply #41 on: August 07, 2007 5:20 am »
looks good. how bout the wishbone mounts?
RE: -4.5
« Reply #42 on: August 07, 2007 5:30 am »
forward a bout 2" but i got to be careful i dont really want another catscan
RE: -4.5
« Reply #43 on: August 07, 2007 6:48 pm »
looks good- i like how the rad shell fits in it's spot.  Is the radiator going to fit there still?  I'm sorta thinking about doing the same thing on my A coupe...maybe even putting the radiator in back...?
RE: -4.5
« Reply #44 on: August 08, 2007 12:25 pm »
the mustang cooling unit should still fit between the rails.  might need a slight notch might not
