November 05, 2026 9:38 pm
Author Topic: sko_ford's A mod  (Read 186547 times)
tubes
« Reply #15 on: January 31, 2007 3:38 am »
heres the cones. the brake i used was alittle outs adjustment thus the dimples on the one cone and one is a bit rounder than the other, but all in all they'll do
RE: tubes
« Reply #16 on: January 31, 2007 4:11 am »
nice work
RE: tubes
« Reply #17 on: January 31, 2007 12:06 pm »
thanks i've been trying.  and its been nice that ive been able to use my sats at school to make some bits and peices
RE: tubes
« Reply #18 on: January 31, 2007 1:03 pm »
yeah they look good.
RE: tubes
« Reply #19 on: January 31, 2007 7:18 pm »
dude, those are sweet
"Cones man, she's gotta have nice cones"
tuesdat at driven
« Reply #20 on: February 21, 2007 4:40 am »
so i was hoping to get the front end all set up to roll under the fargo frame tonight up ,  but i jacked up a inner bearing tring to remove it after i go it a little cockeyed.  but i did get both buick drums bolt patern changed and the ends welded on my bones
new
« Reply #21 on: March 12, 2007 11:36 pm »
heres a couple of new pics with the tires on the wheels and axles and the axles under the frame
RE: new
« Reply #22 on: March 13, 2007 3:21 am »
that pinion angle looks a little off. :P
RE: new
« Reply #23 on: March 13, 2007 3:26 am »
so it the rear spring
hurts motor mounts
« Reply #24 on: March 21, 2007 2:09 am »
so i had a hard time find in a good side motor mount for a later pontiac mill.  i had looked at some home built ones and thought that they were kinda plain looking. but some thing clicked when i saw the hurst mount that arch is useing on his nailhead powered A.  i figured id try to find a set for the 400 and the ones that i did see werent as organic as the nailhead set.  so i decided to fab a similar pair for my motor.  luckly the bosses for the mounts on a pontiac block are perpendiclar to the ground, making the use of angle iron a fairly easy choice. i picked up a chunk of 3x3x3/8 stainless and some 3x1/4 bar stock.  first i found were i wanted the biscut mount to go then i laid out the block mount holes on the other leg.  after drilling these holes i rounded the corners and had hatz tig in the gusset for me.
pics
RE: hurts motor mounts
« Reply #25 on: March 21, 2007 2:46 am »
They turned out great.
sko_ford's A mod
« Reply #26 on: March 24, 2007 1:07 am »
rear end tacked in motor set in frame :)
more
« Reply #27 on: March 30, 2007 12:09 pm »
well with the big show looming on the horizon i've gotten a bit more time with the car  and heres some pics
the spring hanger of my design but cut in fergas(thanks pete)
the rear hung
mock up ot the motor
RE: more
« Reply #28 on: March 30, 2007 2:30 pm »
looks like its coming together.  Ya know a caddy/olds air cleaner would fit nicely on top of that motor
roller
« Reply #29 on: April 04, 2007 4:12 am »
so most of you saw my car at toppers.  so ill keep this short. over the las week i got the frame side motor mounts maid and tacked in(they nee to move back about 2"), fount about were the tru tubes need to go on the frame for the frontr wishbones and hun the rear end
