November 05, 2026 9:50 pm
Author Topic: Re Do the 4De  (Read 41879 times)
Re Do the 4De
« Reply #45 on: May 26, 2010 3:43 pm »
nice
Re Do the 4De
« Reply #46 on: May 27, 2010 3:52 am »
SEXY! :)
Re Do the 4De
« Reply #47 on: May 27, 2010 1:44 pm »
Wow he really did a nice job on them. How is it done?
1/8 inch sheets of plastic, rough cut and glue together.( In the pic I have one turned sideways to show the layers.) He had access to one of those 1 inch wide belt sanders, than buff with compound on a buffing wheel.
See how easy I made it sound. :D
Re Do the 4De
« Reply #48 on: May 27, 2010 2:27 pm »
What did you use to glue them together?
Re Do the 4De
« Reply #49 on: May 27, 2010 3:30 pm »
The place where I bough the plastic had the glue. It's some good shit,once it's set you don't move the sheets. Hase a two year shelf life and it was kind of spendy as I recall.
fomocokid
Re Do the 4De
« Reply #50 on: May 28, 2010 6:41 pm »
The knobs aren't to dificult to make, but very time consuming. I did the final shaping with 80 grit sand paper by hand and then I worked my way up to 1000 grit. I found the best way to polish them was with a small buffing wheel on a dremel. I chose the dremel because you can use a really low speed to avoid losing the point or over heating which can cause melting to occur.
Offline Lord_of_the_Dance
Re Do the 4De
« Reply #51 on: May 28, 2010 8:57 pm »
Great Job fomocokid!!
Re Do the 4De
« Reply #52 on: May 29, 2010 8:59 pm »
You do very nice work. They turned out great! Good to see some people still aren't afraid to work. Tom, they are gonna look killer in the '40. Your lucky to have such a good friend.
Re Do the 4De
« Reply #53 on: June 02, 2010 1:20 am »
I like your knobs Tom!  Kellan- way to go making them; you're a regular Bob Hirohota!  What's the name of the glue, and where do you get the plastic from?
Re Do the 4De
« Reply #54 on: September 13, 2010 3:01 pm »
Quote from: "pinstriper40"
The place is called Plastics Plus, and he sell the glue to use with the plastic. I'm sure if you check around F/M you would find a shop.
Re Do the 4De
« Reply #55 on: September 13, 2010 3:24 pm »
Most of what I have been doing lately is has been under the car. Installing the 200-4R trans and drive line related. Kellan stopped by one weekend and we started to install a gravel pan. I finished it off the rest of the week.
1940 was the last year Chevy DID NOT have a gravel pan. I moved the bumper in 1 1/2 inches and down a 1/2 inch. Cut down a gravel pan from a `41 ( has this neat art deco design ) and welded it on.
Re Do the 4De
« Reply #56 on: September 13, 2010 3:39 pm »
In 1940 Chevy  started to use hidden hinges, but only the top one, left the bottom exposed. ( see pic) So thanks to Tracy I picked up a `41 where they had made both hidden. I hope I can make them work on my `40.
Re Do the 4De
« Reply #57 on: September 14, 2010 2:15 am »
I like that design on your stone deflector.  Are you putting one on the front also?
I think you should turn that '41 into a parts hauler...:)
Re Do the 4De
« Reply #58 on: September 14, 2010 2:53 am »
41 ute
Re Do the 4De
« Reply #59 on: September 14, 2010 12:27 pm »
41 ute
I concur.
