September 29, 2026 8:17 pm
Author Topic: flathead parts  (Read 6028 times)
flathead parts
« on: October 14, 2008 8:31 pm »
Well I gambled on this flathead I saved from the crusher.  I got it running and it appears to have a gopher rebuild (green) shortblock.   Ran great but had 1 dead cylinder.  I pulled the head and there is a crack from the intake seat to the cylinder wall.  Pistons are stamped .030--49-53 block (8rt truck motor).  I found out this is possible to repair but I don't know the cost.  It has the truck water pumps with the nice mounts (wide belt) and a nice truck pan with cleanout, truck bellhousing which accepts the early (48 down) transmission.  I put a rebuilt starter on it.
I'll throw in another set of 8BA heads.
$125.00 and it's yours minus the transmission and the new 12 volt coil I put on.
for another $125.00 you can have the heavy duty 1947-52 open drive 3 speed (the trans was in a 1939 Ford behind a 350 Chevy and still is in great shape).
Reed Overson
Bismarck, ND
701-400-1539
RE: flathead parts
« Reply #1 on: October 15, 2008 4:04 am »
so is that crack something a person sleeves?
flathead parts
« Reply #2 on: October 15, 2008 4:55 am »
I'm not sure.  I didn't spend a lot of time getting the specifics of that type of crack repair.  The flathead guys on the HAMB said it wasn't cheap but could be done.  I don't know what they meant by "cheap".  Maybe Wayne Ruud would give an idea on cost.
But, there's a good crank, rods, .030 pistons, oil pump, valves, lifters, guides, truck pan (they go pretty well on ebay around $80-120), bell housing adapter (they go good on ebay around $65-85), truck water pumps (around $40-50 a pair used), flywheel clutch pressure plate-gotta be worth something, rebuilt starter I just bought for $45, 94 carb is worth $30 for a core, generator, fan assembly.  That's why the add is:--
"Flathead parts"
Got a good block--bore it .030 and put a cheap engine together.
Part it out, cause I don't want too.
OR trade me for other cool stuff of undetermined nature.
 :thumbup:
flathead parts
« Reply #3 on: October 15, 2008 5:06 am »
pm sent
flathead parts
« Reply #4 on: October 15, 2008 1:37 pm »
ON HOLD for racerjohnson (a fine scandinavian boy) pending research and developement.
wlspdshop
flathead parts
« Reply #5 on: October 15, 2008 5:15 pm »
Reed - If racer is not interested let me know....
flathead parts
« Reply #6 on: October 15, 2008 8:54 pm »
I have another one I think will run, Travis.  I have to drag it in and see.  I'm flatheaded-disillusioned.  I'm going back to overhead valve.
Give me a call.
wlspdshop
flathead parts
« Reply #7 on: October 15, 2008 11:13 pm »
Sounds good Reed....I will give you call.
