September 29, 2026 5:34 pm
Author Topic: 64 Pontiac Cat  (Read 7976 times)
64 Pontiac Cat
« on: July 29, 2008 8:04 pm »
Time to thin out the fleet...
1964 Pontiac Catilina 4 door.
The car has a 389 with a turbo 350 transmission.
The odometer on the car shows a little over 800 miles so it has turned over atleast once.
It is equipped with power steering for your driving pleasure.
It has drum brakes front and rear with a single res. master cylinder (needs work).
I put new lifters in the engine and converted it from a points system to HEI.  It also sports stock chrome valve covers.
The transmission is switched to a turbo 350 trans from a car that had 60K on it.
The car could use new wheel cylinders in the back.
The car has new tires on it.
« Last Edit: November 04, 2011 2:59 am by 31Rodder »
RE: 64 Pontiac Cat
« Reply #1 on: July 29, 2008 10:10 pm »
Are the wheels uni-lug by any chance?
RE: 64 Pontiac Cat
« Reply #2 on: July 29, 2008 10:41 pm »
yes the wheels are uni lug.
RE: 64 Pontiac Cat
« Reply #3 on: July 30, 2008 12:01 pm »
Are they 14's?  And if they are, are you willing to part with them seperate?
RE: 64 Pontiac Cat
« Reply #4 on: July 30, 2008 3:45 pm »
Sure, $450 per wheel, right Todd? haha
RE: 64 Pontiac Cat
« Reply #5 on: August 02, 2008 3:11 am »
Nope
RE: 64 Pontiac Cat
« Reply #6 on: May 28, 2009 4:43 pm »
are you all bummed out because you dont have a car to get into Back to the 50's with?  Well here you go, this is old enough to get ya in and enjoy the fun of cruising the fairgrounds.
Re: 64 Pontiac Cat
« Reply #7 on: November 04, 2011 2:59 am »
bump
