June 09, 2026 11:27 am
Author Topic: newer fold down bench seat 47 in neutral gray $40  (Read 3803 times)
« on: July 23, 2008 2:38 pm »
got 2 fold down benches, nice
1950 ford? heater stand alone $35
tri five bell and trans flywheel , clutch link
other GM  3 speeeds   many belhousing SBC
model a radiator nice $125
new block huggers 302 FD painted and fit to engine $75
a lot of new mufflers  $ 5 ea proabbly loud , mostly straight through about 2 1/4 in
tailpipes used w big exhaust  chrome exten, $5 ea  dummie gm PU duals w turbo muffs on same  pipe
exhaust sealer $2 a tin
several exhaust manifolds SBC
3/16 shear about 40 in $1200  3 ph, could switch motor, works great for bkts, ask my column drop??
D and K press brake w lots of dies 4 ft 15 ton $5000
press brake 6 ft needs work $600
big lathe many chucks incl 6 jaw  3 in hole $3500
hand shear china   $50 bigger
louver punch for exhaust tubes, new 2 in to 4 in make your own headder mufflers $8000
muffler domer american hydraulics w dies $5000 for crimping glasspacks
chop saw 12 in B&D $75
fixture bench  got a big one put your rod frame up in air
got a bunch of toggle clamps and some air powered ones
1/4 "air feed drill $30 got clamps to drill round
a whole passle and gaggle of punch presses and feeders and related equip
shop so full cant walk in it
really big lathe will swing rims 15 in 3 j and  4 j $3000
shop ph  218 784 7110
RE: newer fold down bench seat 47 in neutral gray $40
« Reply #1 on: July 23, 2008 7:24 pm »
Any pictures of the fixture bench and price?  You got so much stuff I want but that's the only thing I can get and leave outside.
bench
« Reply #2 on: July 23, 2008 11:15 pm »
it about 6 ft long  40? in wide made of about 4 in angle iron steel p0late and a big parts box built in  and I have the  metal to put it back to original size should be strong enough to hold most any car,  painted black can get a pic if in town on fri
