October 24, 2026 9:10 am
Author Topic: Overspray in Overdrive.  (Read 20682 times)
« on: April 16, 2007 4:02 am »
Can you do a tech article on how you set up your overdrive in your A.
« Reply #1 on: April 17, 2007 2:41 am »
I'll work on it.  Here's some HAMB overdrive stuff.
http://www.jalopyjournal.com/forum/showthread.php?t=173331
http://www.jalopyjournal.com/forum/showthread.php?t=134582
I love my overdrive!! This is about the 6th or 7th car I've had with overdrive. I used the column shift tube from the 51 Ford I scored the engine and trans from, on a 39 steering shaft and box. Everything lined up great. I wired it up in the stock configuration. I'm using much taller (3.55:1) gears so I can run the flathead at low rpm on the interstate. It works good on a light (Model A coupe) car. I run 1st gear-then 2nd gear then either 2nd overdrive to 3rd overdrive or to 3rd underdrive then to 3rd overdrive. 2nd overdrive and 3rd underdrive are about the same ratio. The engine has compression braking in overdrive, but freewheels in underdrive unless the overdrive lockout cable is pulled out (only do this stopped) . You can push the cable in while moving, but only pull it out when the car is stopped. When I come to a corner, I downshift to 2nd (overdrive) and use compression braking. As I enter the turn, or slighhtly before, it automatically downshifts (at about 26mph) to underdrive and goes into freewheel mode. I hit the gas in 2nd underdrive and run her up over 30mph--let my foot off the gas and she shifts into overdrive--then back on the gas til I'm ready to shift to 3rd. In overdrive, cruising, I can stomp on the gas (actuating the accelerator kickdown switch) and drop her into "passing gear" (3rd underdrive), then, when I've passed the late model front wheel drive car, I let my foot off the gas and she shifts back into overdrive. When you park the car with the overdrive engaged, shift to reverse which automatically (mechanically) locks out the overdrive, and apply the park brake.
overspray
« Reply #2 on: May 03, 2007 4:36 pm »
I made a spare OD relay out of an old Ford relay.  I took the cover off and cut out the guts and soldered wires in to plug into a new 12V bosch relay.  A little silver paint, test the circuit and "voila" old looking new OD relay.
« Reply #3 on: May 03, 2007 4:55 pm »
Holy chit!!!!!!!! Not only is he a paint guru, he's a wiring expert too!!!
« Reply #4 on: May 03, 2007 5:11 pm »
nice.
« Reply #5 on: May 03, 2007 5:54 pm »
Tom--if you only knew how many times I picked up the phone to call you!!!  I struggled with this and searched the net intil I found a picture diagram of the bosch relay internals.  Then only after several hours of contemplating the phone call to you, I finally got it through my Norwegian processor and actually figured it out and made it work.
Check out the stress on the processor!!!
« Reply #6 on: May 03, 2007 6:05 pm »
Until now I was glad we could post pics on here. :)
« Reply #7 on: May 03, 2007 6:43 pm »
baah hahah, best laugh I had all week!!! haha
« Reply #8 on: May 03, 2007 6:45 pm »
It's common knowledge that norwegians have the best processors around. Oversprays even looks just like mine.
REAL MEN EAT LUTEFISK (without butter even)
processor
« Reply #9 on: May 06, 2007 6:03 pm »
Process this--O Ball of the Eye!!
RE: processor
« Reply #10 on: May 06, 2007 8:16 pm »
Oh man I hope you got that off the internet. Although it does look better than the other pic you put up. :)
« Reply #11 on: May 06, 2007 11:26 pm »
:lol:  Looks like twins to me.....  :lol:
« Reply #12 on: May 07, 2007 1:58 am »
i figureed id be the first one to moon the board
but then again i already have mooned most of you in public
Re: RE: processor
« Reply #13 on: May 07, 2007 2:01 pm »
Oh man I hope you got that off the internet. quote]
I don't think so, he said he was going to have his girlfriend do that. It's a side of Reed I hope I never see again. :lol:
« Reply #14 on: May 07, 2007 3:26 pm »
Good thing, for you guys, I'm a loving and caring person.
