October 24, 2026 9:54 am
Author Topic: By request, Wheel tech.. turn 15" into 16"  (Read 10546 times)
« on: April 29, 2005 4:30 pm »
Some of you may have seen this on the HAMB. On my Chevy coupe project I want to run '49-'52 style chevy wheels, 15 X 5 on front and 16 X 6 on the rear. Could not find 16 X 6 so I decided to make them. Took a 16 X 6 wheel and cut out the center. Than took the  15 X 5 wheel and chucked it in a lathe and cut it down to fit inside the 16 X 6 rim.
« Reply #1 on: April 29, 2005 4:37 pm »
Took a spindle and a hub and mounted on a table and bolted on the cut down 15" wheel. Slide the 16" rim over, set up an dial indicator.
« Reply #2 on: April 29, 2005 4:40 pm »
Weld inside an out.
« Reply #3 on: April 29, 2005 4:41 pm »
I now have 15 x 5 for the front and 16 X 6 for the rear.
« Reply #4 on: April 29, 2005 4:47 pm »
Thank You!
« Reply #5 on: April 29, 2005 11:38 pm »
Awesome.  Does it end up fairly balanced then by just using the dial?  Or do you just get lucky, er I mean, just that good of a craftsman?  ;-)
« Reply #6 on: May 02, 2005 2:55 pm »
All 4 of the wheels on the mod and the 2 rears on the A roaster have been modified. I have thousands of miles on them and they work fine. I like to think it's craftsmanship but may be it's just luck!!!
