October 25, 2026 7:42 am
Author Topic: Rumors from strangers on the street about Overspray  (Read 17310 times)
« Reply #15 on: May 22, 2006 3:11 pm »
Quote from: "overspray"
.  We still have at least 1 guy here in Bismarck that can figure out how to align these cars without going to a spec book for reference.  overspray
Which guy would that be???
« Reply #16 on: June 06, 2006 12:07 am »
Well, I took it down for exhaust (straight pipes) and that's when I could actually hear the stuck intake valve popping back in the carb.  I searched the net and the HAMB for some flathead Ford stuck valve advice and found some pretty good remedies.  It was on #4 cyl (back right side).  I lubed it with JB 80 and fired it up again--no luck.  So I tried the "pry it closed with the screwdriver trick" and ended up breaking the screwdriver tip off, which, of course dropped in the cylinder.  I ordered a head gasket and pulled the right head off and lubed and tapped until the valve was smoothe and free. Everything seems OK, just a stuck valve from sitting, which is pretty common on the flathead V8.  The engine looks GREAT inside.  I knew it was bored .020 and the crank cut .020, but it looks like they put new valve guides in also and did a fine job on the overhaul.
  I did take it for a spin down the county road, in hopes of the valve freeing up before removing the head, and the 3.55:1 rear gears should work fine with the overdrive.  I'm anxious to get the head back on and have it back up to it's full 100HP.
OH-- did I mention I hate getting greasy doing mechanic work?
overspray
« Reply #17 on: June 06, 2006 1:06 am »
I'll do your mechanic work and you can do my body work! :fucyc:
« Reply #18 on: June 06, 2006 1:08 am »
yea, Me too.  i despise bodywork.
« Reply #19 on: June 06, 2006 3:32 am »
Can I plan on seeing it this weekend at the run?
« Reply #20 on: June 06, 2006 4:25 am »
Yeah I hope to see it at the run, or we will all be going to your house to hang out.
« Reply #21 on: June 06, 2006 12:47 pm »
If I can miss a train ride (not sure yet), I might be able to take it out for a little "jalopy jaunt". (got my HAMB decals in the mail).  I have everything ready to reinstall the head (waaaay easier than an overhead valve engine).  Today I'm finishing the last of the wiring on the overdrive kickdown.  I scored a "Sew-Mor"  de luxe table top sewing machine at a rummage sale, and Kathie is restitching my $1.00 rummage sale seat covers to fit the "vista van" seat.
OH yes Tim, I see by the picture of the Merc, that the "mysteries of magic dent erasing" are coming to full light on the transcendental plain of your Hot Rod existence.  I think it looks GREAT!!  Now comes the "troweling of the RAGE".  (I think there's a post on the HAMB about that).
I hope I'm around to see you guys this weekend.
 1 more cup of coffee and out to the shop.
Remember the anniversary of "D Day" today.
overspray
« Reply #22 on: June 06, 2006 1:32 pm »
Hope you can be there, got the T sorted out and ill be ther all weekend.  would love to see your A this weekend.
« Reply #23 on: June 09, 2006 1:08 pm »
FLATHEAD IS RUNNIN' FINE!!!  I got in last night and in between 2 fire calls, I got the head on and fired it up.  WOW!!  Big power difference from 7 to 8 cylinders.  It really runs smooth.  I'm gonna put the floor pans in today and the windshield.  It's kind of rainy and dismal here today, but I think I can get in a cruise to the run.  I gotta ride the train Sat. morning.
overspray
