October 23, 2026 12:09 pm
Author Topic: Rear Suspension  (Read 9263 times)
Rear Suspension
« on: April 27, 2006 3:39 am »
Found this on Ruffrodders. The suspension is under a shoebox that Bill Hines chopped. Here is a pic of the car and the suspension.
Rear Suspension
« Reply #1 on: April 27, 2006 3:42 am »
NRChopshop gave this explanation: "the bag is on top of the rear bar. this is lift bar only. it does nothing as far as keeping the rear in place. you use a regular 4 link for that. One end pivots at the frame, the other is mounted to a second pivot, just like a shackle, thats mounted to the rear. this allows the bar to go through its stroke without binding. by having the bag mounted on top of the bar you will get more lift and smoother ride. figure a 2:1 lift ratio if the bag is mounted directly in the middle of the barthe bag is on top of the rear bar. this is lift bar only. it does nothing as far as keeping the rear in place. you use a regular 4 link for that. One end pivots at the frame, the other is mounted to a second pivot, just like a shackle, thats mounted to the rear. this allows the bar to go through its stroke without binding. by having the bag mounted on top of the bar you will get more lift and smoother ride. figure a 2:1 lift ratio if the bag is mounted directly in the middle of the bar. the setup works great. great lift, smooth ride. My old truck was setup the same way "
Rear Suspension
« Reply #2 on: April 27, 2006 4:07 am »
Ya, 6 link, what I put on my 90 Chevy.
Rear Suspension
« Reply #3 on: April 27, 2006 2:18 pm »
Quote from: "AntiBling"
Is that a kit, or some thing you built??
Rear Suspension
« Reply #4 on: April 27, 2006 11:37 pm »
Quote
Kit, KP Components was one of the first to come out with the 6 link kits.  Probably 4 or 5 years ago now.
If I was gonna do it over though, I would've made it all myself.  Its bolt in and I want to take and fill all the bolt holes now and weld it in smooth.  One reason is for the asthetics of it, and second reason is I want to weld in crossmembers behind the axle to mount the tanks to but the bolts are all over.
But then again, I got millions of dollars worth of fabrication tools at my disposal now for nothing more than the cost of metal.  So that might have a part to say in me making something like this in the future.   :D
Rear Suspension
« Reply #5 on: April 28, 2006 2:03 pm »
[.  But then again, I got millions of dollars worth of fabrication tools at my disposal now for nothing more than the cost of metal.  So that might have a part to say in me making something like this in the future.   :D[/quote]
I'm think your welding skills ( if they weren't good before ) have got to dam good now!!!
