October 23, 2026 11:15 am
Tech Q and A
Running Gear
spring dearc
Topic: spring dearc (Read 9680 times)
sko_ford
Suedes Member
spring dearc
February 14, 2006 12:09 am »
hers the first one did the laodpedal method
31Rodder
Suedes Member
RE: spring dearc
February 14, 2006 12:23 am »
that seemed to work.
Holy crap that is the cleanest i have seen your work bench.
Moderator
RE: spring dearc
Reply #2 on:
February 14, 2006 4:30 am »
That is awesome Ross.....how much did you take out?
sko_ford
Suedes Member
RE: spring dearc
Reply #3 on:
February 14, 2006 8:43 pm »
went from 6.75 at the main leaf to 3.00
and thats what the bench looked like on sat
Tom
Re: spring dearc
Reply #4 on:
February 14, 2006 9:03 pm »
Is that when you use a bottle jack to do the job??
Never mind I think I see the rig you used setting in the back round. Now the trick is going to be to get the other one the same. Let us know how it turns out.
sko_ford
Suedes Member
RE: Re: spring dearc
Reply #5 on:
February 14, 2006 9:26 pm »
count your strokes
sko_ford
Suedes Member
Reply #6 on:
February 15, 2006 6:31 pm »
second main leaf now matches the first. so now do like i did the first and arch the other leafs to the main or match each one to its counterpart in the other pack?
Tech Q and A
Running Gear
spring dearc
