November 04, 2026 11:07 pm
Author Topic: 15" Steel GM wheels  (Read 9220 times)
15" Steel GM wheels
« on: July 02, 2013 6:50 pm »
Need a pair of fairly narrow 15" wheels with 5 x 4 3/4 bolt pattern for the camper.
Re: 15" Steel GM wheels
« Reply #1 on: July 03, 2013 1:28 pm »
Ryan, Don't know if you through of this but space saver spares are about the narrowest wheels you can find now days. The problem is the offset may not work for you.
« Reply #2 on: July 03, 2013 1:55 pm »
I did think of that and I was concerned about the offset. Also, many of them are fugly. I did a bit of research and found early 60s Tempest/Lemans are 15x 4.5 which would be perfect.
Offline Lucky
  • Cap Shot?
  • Suedes RuLe!
« Reply #3 on: July 03, 2013 3:30 pm »
I am surprised those aren't 5on5 rather than 4 3/4 on 5 bolt circle...
"HOW OLD IS THIS PUG?"
« Reply #4 on: July 03, 2013 3:33 pm »
I think the bigger Pontiacs are 5 on 5, the smaller ones used the smaller bolt pattern, I guess..
« Reply #5 on: July 03, 2013 3:42 pm »
Yeah..........and when was the last time you saw one of those. ;)
« Reply #6 on: July 03, 2013 3:59 pm »
I've got a set of 14" wheels and tires that were on the green bastard I can leave at stefans for you to use till I swap my 15"s
