November 04, 2026 9:24 pm
Author Topic: Finally! Beau from Minneapolis, MN  (Read 17642 times)
Offline Beau
« on: March 26, 2013 2:35 am »
Howdy.
I signed up long ago. I saw an email from the Suedes in my spam folder just as hit 'delete'. Looks like I'm allowed now!
I'll post a bit more info later when I get home.
Beau
Re: Finally! Beau from Minneapolis, MN
« Reply #1 on: March 26, 2013 4:01 am »
Welcome aboard Beau!
« Reply #2 on: March 26, 2013 1:59 pm »
Welcome! You are one of the Delinquents, right
« Last Edit: March 26, 2013 2:00 pm by Wowcars »
« Reply #3 on: April 01, 2013 3:52 am »
Hey cheif glad to see ya made it
« Reply #4 on: April 01, 2013 12:20 pm »
welcome aboard!!
Offline Beau
« Reply #5 on: April 07, 2013 3:49 pm »
Yup, one of the Delinquents.
These are the parts I gathered in the past year to start the build. I'm a year and a couple months in to the whole thing. Been learning a lot. I didn't know the difference between a Model A and T when I started. I had a lot to learn, and still do.
Link to my building and gathering pages-
http://www.jalopyjournal.com/forum/showthread.php?t=667069
- '28-'31 Model A frame
- Model A complete front suspension and steering
- '48-'52 11" Ford F1 complete front axle (for the brakes and spindles)
- Model T buggy spring
- Olds 215 engine/trans/drivshaft/4 barrel intake
- 1930 Model A Cowl, hood, doors and radiator shell
- Model T window frame
- Ford Bronco 9" Rear axle
- New F brake wheel cylinders, hardware, pads and kingpins
- 1919-1922 Fordson Model F Gas Tank
- 1940 Ford truck rims and 16x6.5 Lemans Bias Ply tires
- Drop axle from the infamous Titus
- Model T touring rear body section.
- 35/36 rear radius rods
- Ford F1 cross member
- '40 Ford Wishbone
- Model A wishbone
- Speedway steering arms
- Radius Rods mounts from Pinewood
- F1 brakes, spindles and hubs
- F&R shackles
- F1 motor mounts
- F1 trans mount
- 2 wishbone mounts
- Upper steering arm
- 30-31 lower cowl patch panels
- Rear U-bolts
- 30/31 headlights
- Model A wishbone
- Camaro V-6 T-5
- Brake springs
- F-1 shock mounts
- 35/36 aftermarket tube shock mounts
- F-1 pedal pads
- Reverse eye front spring
- 16" ribbed and smooth trim rings
- 30/31 Hood
- Heater-
- Steel for motor mounts
- Steering wheel
- Front Spring perhces
- Tie Bar, hood lathes, lower shock mounts
- F1 spindle busing, pair
- F1 brake hoses, master cylinder, hubs
- 35/36 Ford Dash
- 23-25 Moel T Turtle deck
- 28-31 Model A headlight
- Ford Hubcap
- T5 S10 tailhousing
- New front wheel bearings and seals.
- New front drums from the rear of a Ford Budget F1 drum replacement NAPA part number 440-1455
- 40 Ford V8 hub caps
- Superbell steering arm
- V8 Hubcaps
- Cork for seals
- 2nd set of F1 brakes
- two 40 Ford wheels
- '32 Ford Radiator Shell
_ '32 Ford Grill insert
- tubing and flat steel
- 35/36 Ford Driveshaft for headers
- 36 Ford Dashboard Waterfall
- S-10 9 1/8" Clutch kit
- '36 Ford waterfall, gauges and ash tray
- 27 Ford Stanchions
- 28/29 headlight bar
A week after I started-
After I moved into a new work space-
Chassis work-
2" channel and a bit more work-
...and with some smaller tire to see what a little rake would do.
« Reply #6 on: April 07, 2013 4:59 pm »
Looks good and welcome aboard, I've been following your build when I can on the HAMB.  Did you shorten the wheelbase or is that stock A wheelbase?
Offline Beau
« Reply #7 on: April 08, 2013 3:10 am »
It's pretty short, measuring in at 91.5".
« Reply #8 on: April 08, 2013 2:51 pm »
That looks great. Love to see it on the street.
