November 05, 2026 12:05 am
Author Topic: Four link setup  (Read 9740 times)
Four link setup
« on: September 11, 2012 9:30 pm »
Anybody have advice on a fairly economical triangulated four link setup for the Stude? With the stock SBC and s-10 rearend, I don't anything that is capable of planting 700hp or anything. Just want to redo the rear suspension to be able to pull the camper. I'm thinking of bags in the rear also.
« Last Edit: September 11, 2012 9:46 pm by Wowcars »
Re: Four link setup
« Reply #1 on: September 11, 2012 10:28 pm »
Not a 4 link but I see alot of people using the chevy truck rear arms or a home made I beam type arms. I think everyone I have seen is running bags as well.
« Last Edit: September 11, 2012 10:48 pm by Eyeball »
Re: Four link setup
« Reply #2 on: September 11, 2012 11:17 pm »
Dad put a set of those Truck rear arms under the 53 Buick, and they worked out great..  id Highly Reccomend going that way.
Re: Four link setup
« Reply #3 on: September 12, 2012 6:42 am »
When I looked in to it for the shoebox you could get used nascar arms for around 150 a pair
Offline AdamNDebbie
Re: Four link setup
« Reply #4 on: September 15, 2012 2:03 am »
I completely built my own for the '62 Merc.  This was about as cheap as you can go.  The shocks are stock, still in the factory location and mounts.  The lower outside control arms use the original forward spring mounts.  All bushings are universal Energy Suspension urethane bushings.  I built the arms out of DOM tubing (8 ga. wall).  Adjustment is done by sliding the axle on the outside control arm mount, this changes both pinion angle and axle location. Hopefully this gives you some ideas.
Ignore the fact that there is only one pipe, the other will be there shortly.   ::)
« Last Edit: January 05, 2013 3:34 pm by AdamNDebbie »
Do Bird's Eat Beans to Fly Faster???
Offline tokyo
  • dongs!
    • My50merc
Re: Four link setup
« Reply #5 on: September 16, 2012 1:59 pm »
i put the chevy trailing arms in the merc.  I have seen them on other early fords as well...they are really pretty easy and lean to the bag set up pretty nicely.
I once had a really big deck.
Re: Four link setup
« Reply #6 on: November 06, 2012 2:02 pm »
Thanks everyone. I've decided to go the truck arm setup and found a pair of Roush Nascar arms on Ebay with the panhard bar. UPS said it should be here Nov 15! It'll be nice to finally not have to be concerned about the rear suspension on that thing.
