November 05, 2026 1:45 am
Author Topic: 283 or I6 235 Water Pump Pulley  (Read 4890 times)
« on: September 09, 2010 4:40 pm »
I believe these are the same size and depth when the 235 pump is a longer shaft like the one on my engine. I may just get a shorter water pump, but I'm better off pushing the rad forward for clearance with the longer one.
Thanks.
« Reply #1 on: September 09, 2010 5:30 pm »
Years ago I did what you are proposing, and I recall just pushing the hub down on the shaft farther with a press and using a shallower pulley off a 327 or maybe a 283. It worked very well. Also I recall doing just a tad bit of grinding on the waterpump where the pulley just kissed it...
« Reply #2 on: September 09, 2010 5:57 pm »
There is a press in the shop....
I still may need a pulley then. I'm going to get the original one from the guy I bought it from to get some measurements/ weigh my options. Thanks Weed.
