September 29, 2026 8:17 pm
Author Topic: Back to the 50's 2010  (Read 20257 times)
« Reply #30 on: June 22, 2010 2:07 pm »
Had a great time even though I only had one day to be there.
It was great getting to chat with you Tom, I learned about Model ARs and got to talk to Aaron and his father a bit.
Jake your Ford is beautiful, can't wait to see it all finished.
« Reply #31 on: June 25, 2010 10:50 pm »
l.
Also met Deucekustoms, he was not having a good day.
where do i start... since i was still finishing the car up at 2am thursday I never really had much time to really work the bugs out, so I guess 50's was the time to do it... Thursday on the way down my throttle linkage came undone going down 94, and my water pump went out. friday I changed the pump, got to 50's and my right front brake was locked up, i was running hot already before that, so forcing my way thru the fairgrounds to find a parking spot put me at about 280 degrees...my radiator sounded like my horn honking!  after it cooled down i got the brakes adjusted and moved into the parking lot by the grandstand. saturday morning i pulled the RPV's off of my brake lines after finally figuring out that I didn't need them after all, as they were causing more harm than good anyways. leaking when they were cold and building pressure when they got hot. bled and re-adjusted my brakes, and pulled out my thermostat, and seemed to be going good, but got hot agian as soon as I got to the fairgrounds and before I parked there was coolant leaking into my cab and steaming up my windshield, damn heater core took a puke. once it cooled down i bypassed the heater core and I never broke 200 degrees the rest of the time, apparenty that solved my cooling issue. who knows. I made it home just fine, but I am sure glad I was staying at Titus and Jennies so at least I had a gargage, tools, and some help keeping my car alive this weekend.  it was definitely still a fun time, and hell would it be 50's without car trouble??? thats half the fun, seeing how good your MacGuiver skills really are!
« Reply #32 on: June 25, 2010 10:52 pm »
oh and Tom... this was the first time I have seen your car in person, but IMO it looks 800 times better with the box!
