November 05, 2026 12:03 am
Author Topic: Pinstriper49's 49 Shoebox (Formerly SKOFORD'S)  (Read 161459 times)
0 Members and 2 Guests are viewing this topic.
« Reply #75 on: December 07, 2009 9:09 pm »
Last I saw of them was after he called and left a message for us to go get them, they were sitting in the dumpsters he was using to haul the cars over to the crusher. :(
« Reply #76 on: December 12, 2009 4:08 am »
I started to peak the hood today.  I took Brian's suggestion and got some 1/4" square stock.  I bent it tofit the contour the way I wanted it to and tack welded it in.  I then welded from the square stock down onto the hood.  I hope to make it super smooth with lead sometime in the future.  Plans are to lead the headlights too.
« Reply #77 on: December 12, 2009 6:38 am »
That looks like it worked good. Keep it up!
« Reply #78 on: December 12, 2009 6:56 am »
I started on the trailing edge of the peak towards the middle of the hood...  It got a little wavy but I don't think it's too bad.  I'll have a couple spots to try and shrink out or something... I'll have to see how it all turns out before I mess with it too much.
« Reply #79 on: December 12, 2009 8:33 pm »
Looks good! Saw your post on the HAMB and noticed you are looking for headlight frenching rings. I wanna french my headlights too. I looked for quite some time and a couple of weeks finally found a set of steel '52's but I came across these earlier on Egay. Little spendy but so are real '52-'53's. I got lucky and did some machining work for a guy in exchange for a chance to scrounge his junk pile. Anyway check out the link, might be an option. Keep up the good work. BTW: should be getting your steering column out next week or the week after for sure.        http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=390122979848
« Reply #81 on: December 12, 2009 9:58 pm »
Eyeball had pointed me to those as well- I think I'll go with them.  Later on today I'm going to try and fix the hood.  It might take a while.  Anyone have a sponge they can lend me?
« Reply #82 on: December 13, 2009 2:41 am »
Keep it up Joel. :)
« Reply #83 on: December 14, 2009 2:01 pm »
I think I still have a set of headlight rings for frenching. I won't be able to check till this weekend.
« Reply #84 on: December 14, 2009 5:31 pm »
Keep it up Joel. :)
Thanks Jake, I will!  Now that x-mas break is coming I'll get a lot done!
« Reply #85 on: December 14, 2009 5:32 pm »
Cool... are they like the ones flatheaded posted?  If so I want them if they're available.  If they're hagans you can keep them...
« Reply #86 on: December 14, 2009 5:48 pm »
no, no, none of that hagans shit! These be genuine Ford.
« Reply #87 on: December 15, 2009 1:14 am »
Ohhhh!  I didn't think you'd have any of hagan's shit.
« Reply #89 on: December 19, 2009 9:46 pm »
Pete- I like that a lot too.. I'm now second-guessing hardtopping it... I'm just not sure if I want to or not.  As of late I've seen a lot of cool "b-pillared" sedans.
