October 24, 2026 12:07 pm
Author Topic: Did a search, couldn't find info. Model "A" axle w  (Read 5535 times)
Ricola
« on: October 28, 2007 4:59 pm »
Anyone have a model "A" rear axle laying around? I'm looking for a width from backing plate to backing plate and bolt face to bolt face.
RE: Did a search, couldn
« Reply #1 on: October 29, 2007 5:56 am »
I do. I'll measure it if i think of it. If I remember right the wheel mating surface to wheel mating surface is 58" even.
« Reply #2 on: October 29, 2007 3:59 pm »
I don't have one to measure, but I'm pretty sure the inside backing plate to backing plate measurement is 50 1/2 inches.  If you're looking for a good axle to fit, check a 74-80 Mustang II (6cyl). The housing measurement from end to end is 52".  I've used them in 2 A's. It is an 8" with the pumkin removed from the front.  Fits in perfect although you have to have the axles drilled for your bolt pattern.
Ricola
« Reply #3 on: October 29, 2007 4:16 pm »
Cool thanks!
