October 24, 2026 10:30 pm
Author Topic: Ford Model A Roadster  (Read 136837 times)
cowl
« Reply #60 on: November 21, 2009 10:14 pm »
Today I worked on the cowl.  I had to make a pie cut to help the bottom of the cowl flow with the 32 frame.  Without the pie cut I would have to run an ugly filler underneath the body to lift it up. I now have the body mounts complete too so it is now bolted down.  I will finish welding the cowl panels this week.
RE: cowl
« Reply #61 on: November 22, 2009 2:14 am »
Looks good Todd.  Lots of stuff goin' on with the builds now.  Fun to see.
RE: cowl
« Reply #62 on: November 23, 2009 4:24 am »
Looks sharp Todd!  What's next?
RE: cowl
« Reply #63 on: November 23, 2009 1:24 pm »
Yeah..........that will work. You will have to make a mount on the inside of the frame for the front body mount......right??
Re: RE: cowl
« Reply #64 on: November 23, 2009 1:48 pm »
yes, i made a tapped tab on the inside of the frame rail that the front of the cowl mounts to.
Re: RE: cowl
« Reply #65 on: November 23, 2009 1:53 pm »
good question, I think I will work on the doors where the latch mechanism bolts to... the old nuts are missing or rusted away so I need to do repair to those areas next....  if I remember right there are three mounting points and I  have one good one per door.
RE: Re: RE: cowl
« Reply #66 on: April 08, 2010 5:37 pm »
I am making some progress on getting the front and rear brakes all ready to go.
I am using 32-34 spindles up front, they have been modified to use 48 ford backing plates.
I like the look of the built in steering arm on these spindles.
Also I am waiting on my brake linings to arrive so I can get them installed.
« Reply #67 on: April 08, 2010 7:39 pm »
I've got the little set tool and punch to rivet your linings to the shoes if you need one to use.
« Reply #68 on: July 14, 2010 12:58 am »
I cant believe I haven't done an update in a while.
Brakes are done.
I went thru the transmission and replaced one gear. so the transmission in done also.
I am now waiting on some gaskets to arrive to finish up the motor and make it look purdy.
« Reply #69 on: July 19, 2010 6:50 pm »
Today I converted the generator from 6v to 12v.
« Reply #70 on: July 19, 2010 8:12 pm »
When do we get to hear it run?  It'll be a great day!
« Reply #71 on: July 19, 2010 8:37 pm »
More info please ( how did you do that?? )
« Reply #72 on: July 19, 2010 8:42 pm »
What he said.
genny
« Reply #73 on: July 20, 2010 3:56 am »
Prolly just changed the field coils right Todd? Thats how I did mine on my T...
RE: genny
« Reply #74 on: July 20, 2010 4:39 am »
yep, just used the center section from a 12v and the ends from the 6v. goes together in just a few minutes.
