October 24, 2026 7:29 am
Author Topic: Crank install  (Read 7785 times)
Crank install
« on: May 08, 2007 6:14 pm »
Pulled the crank out of the 350 thats going into the Stude and having Wayne polish or grind it, whatever it needs.  I made sure the caps are in order and will go back correctly. I'll also be replacing the oil pump, seals and, obviously bearings.
Any other words of wisdom on dropping it back into the block? I can't remember how long its been since I've done a crank install.
RE: Crank install
« Reply #1 on: May 08, 2007 6:56 pm »
The only thing I would add is to replace the input seal on the tranny. They ALWAYS leak. And take a look at the balancer you may want to think about a speey sleeve for the that too.
rear seal
« Reply #2 on: May 08, 2007 10:51 pm »
I always spin the rear seal in the block a little so the parting seams are not lined up with the parting seams on the block, makes for less leaks.
RE: rear seal
« Reply #3 on: May 09, 2007 1:13 am »
Well, as it turns out, the crank is shot anyways.
Plan C!
RE: rear seal
« Reply #4 on: May 09, 2007 1:18 am »
I would reconsider dropping the crank in unless your aim is better than mine. I would carefully set it in the block instead.
RE: rear seal
« Reply #5 on: May 09, 2007 1:20 am »
and if your crank is shot, I have one in Fergus.
Re: RE: rear seal
« Reply #6 on: May 09, 2007 2:19 pm »
. . . whoever your machinist was, he was definately hungover when he did your crank.
I brought it over to Wayne Rud, he took one look at it and said it was shot. It never even saw the grinder.
...mmmmm....grinder
RE: Re: RE: rear seal
« Reply #7 on: May 09, 2007 3:24 pm »
yea, i was in the middle of writing my book up there when you posted that it was shot, oops. Need a crank?
