October 31, 2026 10:53 pm
Author Topic: Eyeball- Are these the same wheels?  (Read 4184 times)
Zorch
« on: March 20, 2007 4:04 am »
I noticed your coupe has what looks like some mid thirties mopar 17" wheels...  I picked some up at an auction last fall that I think are the same.  I was thinking they're Plymouth but they could be Chrylser.  Maybe the same...  Anyway, how did you adapt them?  I think they have like a 4.75" bolt pattern.
« Reply #1 on: March 20, 2007 5:25 am »
They are different. Mine are 16" x 5" and have a 5 x 5.5 bolt pattern. If you look at mike they have another ring on the center of the wheel too.
Zorch
« Reply #2 on: March 20, 2007 6:21 pm »
Yeah, you're right.  Son of a B.  I want to run these but I don't want to monkey around with adapters or machining my drums.  As well 17" cokers aren't cheap!  Oh well Matt hooked me up with a set of 16" Ford steelies.
« Reply #3 on: March 20, 2007 6:29 pm »
Yea they are cool and I think you are correct that they are Plymouth or some mopar. How many do you have?
Zorch
« Reply #4 on: March 20, 2007 7:03 pm »
4- I got two at an auction and found two more at a salavage yard.
« Reply #5 on: March 20, 2007 8:10 pm »
Since you have all 4 I would re-drill the hubs with the correct pattern and run em. It usually isn't a problem if you are going down in size but you can sometimes run out of meat going the other way.
