October 26, 2026 12:32 am
Author Topic: 53-56 F100 Steering Box and pitman arm  (Read 5065 times)
« on: February 13, 2007 1:45 am »
Looking for one in good condition.
« Reply #1 on: February 13, 2007 2:11 am »
You do realize they have that big ugly pitman arm that clamps on the shaft.  I have one I was going to use but decided against it because of that big pitman arm.  I have seen them on several old rods in the "little books".  I'm not sure where I put the pitman arm, but I can probably find the steering box and column and maybe the arm will turn up if I dig enough.
Offline eberhama
« Reply #2 on: February 13, 2007 3:23 am »
Keep in mind that '56 is shorter than 53-55. That is why it is the column of choice. Also look for one the the adjuster is not screwed all the way in, these boxes are spendy to rebuild. Finally, make sure it doesn't have "Gemmer II" cast into it, these are out of big trucks and are larger and have a longer pitman. I wish you'd have said something earlier, I've sold 5 of these in the last 6 months.
« Reply #3 on: February 13, 2007 7:13 am »
I have one out of a '54. Steering wheel, column, box, and pitman arm. You'll have to determine what "good" condition means on a 50 year old steering box. I'll trade you a stromberg top for it all.
