October 30, 2026 8:55 am
Author Topic: So how would you make this?  (Read 5360 times)
« on: January 09, 2007 11:32 pm »
This is a tapered shim used to mount a F1 steering box in a 32-34  frame.
RE: So how would you make this?
« Reply #1 on: January 10, 2007 3:02 am »
you could cut it with a band saw.  I tried to cut straight with one and it came out at an angle like that.
cutting straight
« Reply #2 on: January 10, 2007 1:55 pm »
hahaha. I was thinking the same as Todd
RE: cutting straight
« Reply #3 on: January 11, 2007 1:31 am »
Mill and someone who knows how to use it.  Or if you're feeling spry, you could use a belt sander to wear it down to that angle.
« Reply #4 on: January 11, 2007 3:45 am »
could you just use washers in vering heights?
« Reply #5 on: January 11, 2007 3:56 am »
I may do that. I think it will put alot of stress around the bolt holes but should be ok.
Re: RE: cutting straight
« Reply #6 on: January 11, 2007 4:11 am »
How about cutting steel bushings down to sizes needed, then get a plate, thinner than the smallest thickness, and weld the bushings into that.  Relieve some of the stress.
KustomOz
RE: Re: RE: cutting straight
« Reply #7 on: January 12, 2007 9:14 pm »
If you can get me dimensions I can mill one out for you next week. draw it up and give me a call this weekend. 361-3091.
 Oz
