October 30, 2026 3:15 am
Author Topic: sko check this out.  (Read 5097 times)
RE: sko check this out.
« Reply #1 on: January 02, 2007 4:33 pm »
http://www.jalopyjournal.com/forum/showthread.php?t=124496
another 57 ford 9 inch. $125 Rochester, mn
sko check this out.
« Reply #2 on: January 03, 2007 11:13 pm »
I'm using that 8 inch I got from you trading.  I found a 3.55 pumpkin at Brady's for it.  The 35 Plymouth artillery wheels fit right on.  Tom and I went to the "combine" junkyard last week.  I picked up this frame (that I have walked by for about 8 years)  off a mid 20's Dodge (brothers).  I have it in the shop where it will undergo a study session while listening to oldies and sitting on the shop stool.  Some time with the tape measure and a loose "mock-up" will determine if it will do the trick.  I like the lines and the kick-up in the rear.  I'll have to narrow it slightly  for a channel.
overspray
sko check this out.
« Reply #3 on: January 03, 2007 11:38 pm »
That is a neat lookning frame. It looks like it may kick (sweep) up a bit at the front too.
sko check this out.
« Reply #4 on: January 04, 2007 3:08 pm »
No, but it might when I'm done.  "Large" Gary was over last nite and we measured it for the 31 cowl.  It looks like I can channel the homemade RPU over the rails, add some different crossmembers and box it up.  The rear kick is about 4 inches.  I might as well cut up them 32 frames for parts.  I'll take your torque tube out first.
overspray
sko check this out.
« Reply #5 on: January 04, 2007 3:45 pm »
Quote from: "overspray"
overspray
ha ha ha!!! I take the left front 4 feet. ha ha
