October 29, 2026 9:13 am
Author Topic: King Pin Size  (Read 3905 times)
King Pin Size
« on: December 04, 2006 11:03 pm »
anyone know off the top of your head if the the king pin diameter is the same on model A/B's as the later ones?
king pin size
« Reply #1 on: December 05, 2006 1:57 am »
accordoing to my ol ford Street Rod book it looks as though the diameter is the same but the length and location of the lock bolt vary;Goes on to say"When buying a king pin set, get the set for the spindle you are using. If the lock bolt  slot does not line up with the axle you have selected, grind a new slot on the opposite side of the king pin. Lock pins are intended to be inserted from the front side of the axle." Also it says 37-41 king pins have a flat top, 5.1/2 inches long and have the lock bolt slot 2 .1/2 inches from the top. 42-48 pins are six inches long, with the lock bolt slot 2 3/4 inches from the top.
RE: king pin size
« Reply #2 on: December 05, 2006 2:29 am »
yes diameter is the same as far as I know.
RE: king pin size
« Reply #3 on: December 05, 2006 2:30 am »
ahhwell I missed the end of the auction for a reamer.
