October 25, 2026 12:22 pm
Author Topic: headlight cup and a good machinist loyal to our cause  (Read 22219 times)
Re: RE: Re: RE: Re: rearend
« Reply #15 on: December 05, 2006 2:49 pm »
He does know that machining the bells alone is about $200 bux. He is just ordering new axles from Moser.
If you have to have the machine work done it's goin to be spendeeeeeee.
The HOT Rod mag article is from Nov. 1960. They used '49 to early'51 Merc  so they could keep the 5 on 5 1/2 bolt pattern. Beside machining the carrier you need to grind down the axle gears to fit inside the carrier.
Got to thinkin it was Randy Zeller who told me to use 49-51 Ford. He had done it and said the spiders and axle gears didn't mesh that good.
My new ROD and Custom was in the mail when I got home last night. They show the Hot Rod Works doin this. I think if you got their side gears they would mesh better.
Interesting, the old HOT Rod article showed how to do it with junk yard parts, the new mag shows how to do it with advertiser's parts. :roll:
RE: Re: RE: Re: RE: Re: rearend
« Reply #16 on: December 05, 2006 3:03 pm »
Here is a link to their site with all the info.
http://www.hotrodworks.com/shopdisplayproducts.asp?id=7&cat=Axle+Upgrades%2C+Ring+and+Pinions+%26+Components
The 28 spline spiders are $225.00
Re: RE: Re: RE: Re: RE: Re: rearend
« Reply #17 on: December 05, 2006 3:54 pm »
Waht me to pick them up for you when I go to Bville next year??
RE: Re: RE: Re: RE: Re: RE: Re: rearend
« Reply #18 on: December 05, 2006 4:21 pm »
HAHAHA no.....I have Randy getting me some stuff. I don't think I will be doing the convertion. I am going to run with the stock rear brakes, brngs and drums......that is if I can find some.
Re: RE: Re: RE: Re: RE: Re: RE: Re: rearend
« Reply #19 on: December 05, 2006 5:15 pm »
Same here, see what I can get away with. Stock axles, pitted bearings and races, pitted ring and pinion, lets race!
I have those drums and stuff for ya.
Re: RE: Re: rearend
« Reply #20 on: December 05, 2006 5:19 pm »
the idea is to keep the big bolt pattern on the axles
Yes I realize that is what most guys want, but I will be using the small Ford pattern.
Cool, tom. Sorry, just trying to steer the ship a little. What car are you putting these axles and wheels on? is it the roadster with the aprons? is it time for a project progress report yet? I'm stoked to see it.
« Reply #21 on: December 05, 2006 5:40 pm »
Hey racer, no apology necessary. The banjo converted to new axles is for a 30 roadster project I want to do after I do my 34-35 Chevy coupe after I redo my '40 convert to a custom after I finish the aprons, hood, tires and wheels on my '28 roadster. It keeps me young. :cheers:
« Reply #22 on: December 05, 2006 5:47 pm »
Just for the record MR. Johnson is loaning me some stuff so I can roll so I still need a set of drums and hubs if anyone is hoarding them out there. :)
« Reply #23 on: December 05, 2006 6:41 pm »
Pitted bearings? somebody say pitted wheel bearing?
« Reply #24 on: December 05, 2006 7:49 pm »
Quote from: "tracywiedrich
 :lol:  :lol:  :lol:
RE: Re: RE: Re: RE: Re: RE: Re: RE: Re: rearend
« Reply #25 on: December 05, 2006 11:10 pm »
i don't get it. . . .
« Reply #26 on: December 05, 2006 11:13 pm »
'28 roadster? pics? now i'm interested!
 i can't get enough 28-29 roadster pics right now before i go down a certain fork in the road
Re: RE: Re: RE: Re: RE: Re: RE: Re: RE: Re: rearend
« Reply #27 on: December 05, 2006 11:20 pm »
When Tom and I were on our way out to Fargo to hook up with the Hunnert gang I lost a rear wheel bearing...thought I'd get lucky with old pitted wheel bearings also, didnt work, but luckily I had a new bearing and axle in the trunk...You brought back a bad memory that was jus starting to fade from my memory...haha
RE: Re: RE: Re: RE: Re: RE: Re: RE: Re: RE: Re: rearend
« Reply #28 on: December 06, 2006 5:18 am »
you carry axles in your trunk? dude. . . .
. . . .i just ordered new bearings and races.
Spare Axles
« Reply #29 on: December 06, 2006 1:46 pm »
I did this time cause we were on our way to Illinois.
