October 23, 2026 3:33 pm
Author Topic: stuck brake drums.  (Read 6216 times)
stuck brake drums.
« on: September 07, 2006 2:55 am »
I need to remove brake drums from a 9 inch ford.  I broke the outer lip on the one side and would like to salvage the other if possible without breaking it.
So what have you done to loosen these up.  I am guessing the pad is stuck to the drum.  the adjuster are rusted and can not be turned.
I shot a bunch of hydrotex (lubricant) in the adjuster holes,  Do I just wait?
Or give me some options.
RE: stuck brake drums.
« Reply #1 on: September 07, 2006 3:24 am »
They were stuck? we pulled that car to the shop to cut the rear end out.. and ithad wheels on it..      Hmmm
Heat em up..   i had to do that to the rear in my edsel..  its the axle flange thats probably stuck, not the brakes.  the hole ih the drum, wheere the axle fits thru...  I heated and Gibbs'd mine for a full day before it finally came on my Edsel.
« Reply #2 on: September 07, 2006 3:49 am »
Cut the little pins out from the back that will give you some play.
