October 25, 2026 2:10 am
Author Topic: Wheels again  (Read 15441 times)
Wheels again
« on: September 05, 2006 4:00 pm »
Looking for 2 ea. 16" X 5 or 6" wide w/ a 5 on 4 1/2 bolt pattern. I know the ford crown vic has them but they are 7" wide and they will not accept a small cap. Been told '49 or '50 ford had them as an option. Even if you don't have the wheel but know of some thing else that will work let me know.
Thanks.
RE: Wheels again
« Reply #1 on: September 05, 2006 5:10 pm »
Tuck is running a set of 16 on his shoebox. From what I understand they are pretty hard to get ahold of.
Wheels
« Reply #2 on: September 05, 2006 6:04 pm »
I assume you are looking for a solid steelie type wheel right? I do have a full set of artilliary style wheels off a Internanational pickup but dont really wanna part with em. I would check Corn Binders, they had the small bolt pattern and should have had 16's into the 50's. Mine are from a 35 International.
RE: Wheels
« Reply #3 on: September 05, 2006 6:44 pm »
Yeah, for the back of the '28. Need to be able to mount those '49-'50 style caps I got.
Serious was giving me shit this weekend about changing tires all the time. :)
wheels
« Reply #4 on: September 05, 2006 8:05 pm »
Just remembered where there is a 49 or 50, try to check it out tonite...prolly be 15's though...let ya know
Re: wheels
« Reply #5 on: September 06, 2006 3:26 pm »
Quote from: "tracywiedrich"
Did you get a chance to check it out?
RE: Re: wheels
« Reply #6 on: September 06, 2006 4:38 pm »
I suppose you want em for this weekend huh? I hope I am able to make it down there.
RE: Re: wheels
« Reply #7 on: September 06, 2006 5:24 pm »
Naw, don't need them till next spring. Got a guy on the HAMB who wants to sell me two, but.... if I can get them local, that would be even better.
If you don't make it down will have to stop by on the way home Sunday to pickup Char's sweatshirt.
RE: Re: wheels
« Reply #8 on: September 14, 2006 2:45 pm »
I think I got this figured out, Most 37-48 Plymouth's had 16X4s, the later ones have outside bumps which will hold the caps I want to use. Any mopar guys out their that can help me out??
Re: RE: Wheels again
« Reply #9 on: September 18, 2006 1:55 pm »
Found two this last weekend at a Minot junkyard.
RE: Re: RE: Wheels again
« Reply #10 on: September 26, 2006 5:11 am »
tom can you post a pic of the rim you got from minot.
Re: RE: Re: RE: Wheels again
« Reply #11 on: September 26, 2006 4:10 pm »
I'll try to rmember to do that tonight.
« Reply #12 on: September 27, 2006 3:01 pm »
Here ya go. The center hole is to small for my axle flange, will have to open it up when I widen the rims.
Also checked the price on the ss hairpins w/clevises  $355.00
RE: Re: RE: Re: RE: Wheels again
« Reply #13 on: September 27, 2006 5:30 pm »
Who had the hairpins?
Re: RE: Re: RE: Re: RE: Wheels again
« Reply #14 on: September 27, 2006 5:54 pm »
Quote from: "wowcars"
Gotem new form the So Cal speed shop that was in Colorado Springs in 2003.
